I have sony ericsson k770i camera problem.... whenever i open my camera, my mobile restarts everytime.. First, black screen comes and then my mobile reboots.. :-@
I dont know... what should i do... plz help me...
Main menu--Settings--General--Master reset: This will reset the phone back to its original factory settings, so make sure you back up your phone on PC/PC Companion/memory card beforehand.
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/pccompanion/k770i?cc=gb&lc=en Try running a software update or repair using PC companion and failing that, try a master reset.
I use that software in past... my mobile was perfect.... but when i use this software, my mobile started doing this camera problem...
During process, my mobile turned off and didnt turned on... then i flashed my mobile.... but still i have this problem...
So can you now access the menu in order to perform a master reset? If not, then try reflashing the phone.
Sir, i can't understand what u r trying 2 say... 😕
How can i perform a master reset? And what is this?
Thankx sooo mucch sir...
Problem solved.... Thank God....
No worries, that's great news!
Yeah....
how to change front camera for 3G K700?
