Recovery of deleted photos
is it possible to recover deleted photos from the SD card !! i have been told that they are still stored somewhere ??? Please help
11 REPLIES 11
Dr_Chris
Champion
Try one of the file recovery programmes available on the internet.
Hey, I just want to let you know that the photos or data that are not totally wiped out from your sd card even if you delete it and you can recover it by using some photo recovery software but make sure to not save any more data on your sd card until you recover your deleted photos.
I would like to suggest a trusted one software here. First, downlaod and run the free version of the software on your computer system below-
http://www.stellarphotorecoverysoftware.com/download.php
And now connect your sd card to your computer and follow the instruction. Soon, you will see the preview of recoverable photos from your sd card. If you are satisfied with the preview, go for the full version of this photo recovery software and resotre your deleted photos.
Hope it will sure help you.
slimshaddy
Hero
Winking_Face
marcus12
sorry to wake this thread up, but I tried all the solutions above but none of them helped me recover deleted photos from my mobile phone, and I continued serached and asked around and I found a mobile phone file recovery guide which did helped me get back deleted photos. So I'd like to share the solution here so that other people who has same experience as me can restore deleted photos from the mobile. Here's the tutorial I mentioned: How to recover deleted photos from mobile phone
sunshinegreen
The photos deleted from SD card can be retrieved as if they were not overwritten by new data. Here is a guide about how to undelete photos step by step.
yad99in
You can try stellar phoenix photo recovery, recently new version 6.0 is lanuched and it is much advance then the previous version 5.0.  It is specially designed for memory card and SD card recovery. Can scan up to 2 TB storage media.
bonnas
After reading your post, I have thought about the data loss problem of my phone Micro SD card. At that time, after attaching this phone card to computer, the Windows always asked me to format it before using and I had no choice but to format it afterwards. And then, all stored stuffs were lost with that formatting process.
So, to re-view them again, I had searched a lot over the internet and finally got most of my stuffs back with the guidance of a related video tutorial.
So, if you really have no luck to get your videos back, this tutorial may also help you somehow.
Also read more detailed information of data recovery:
http://en.wikipedia.org/wiki/Data_recovery
https://www.youtube.com/watch?v=7PAMc6eNPbU
Hope it will work for you.
Fool1
No matter how or why you deleted your SD card photos, don’t panic. Just do nothing to this SD card and insert it to your computer. And then, download some data recovery software to see how many of your original card stuffs could be restored successfully.
Here are some articles that can introduce you how to restore your lost card data:
Or http://en.wikipedia.org/wiki/FreeUndelete
No matter which one you prefer to use, just use the selected one to scan your SD card more times and see whether you can rescue all lost photos back.
Make and update SD card photo backups well in the future.
