notification tone not working for my xperia P.
silantharakans
notification tone not working for my xperia P. What to do now?? Its vibrating but not ringing the tone while a new message or other notification is displayed.
piotrom87
SMS notification sound goes to silent in some time after 6.1.1.b.1.54 and 6.1.1.b.1.75 update.
Is is due to other sound notifications (in many aplications like facebook, yahoo, etc).
You can try to fix it by SUS or PCC but the problem comes back...
It is STILL NOT FIXED...
SONY, please fix it in Jelly Bean !!!!
It is one of two most annoying problems (the second bug is half-dark photos on 8 mpx) Slightly_frowning_Face
18 REPLIES 18
profile.country.RO.title
_alexdon_
Maybe your phone is on silent mode vibration only,you can see that in settings-sound.
alexdon
silantharakans
No. It's not in silent mode. I'm getting the ring tone while the incoming call comes. I'm also getting the notifications including sms notification without tone. Balance notification after the call or sms is also obtained without tone. While restarting the phone, I'm getting the notification tone for some time. But after 15 min of restarting, it goes to the previous state, notifications without tone.
_alexdon_
I have heard about this problem before,i think it needs either uninstalling apps like viber or whatsapp(if you are using) or repairing the phone with sony update service.
alexdon
florenzgonzales
this thing actua;;y happened on my phone but repairing it using PCC and SUS  fixed the poblem
Sam
Legend
Legend
The update is likely to fix it, however you can also try setting a different tone for the notification.
silantharakans
I'm not using apps like viber or whatsapp. But I'm using nimbuzz. What about nimbuzz?? Is it the reason for the problem??
Otherwise, How can I repair it with sony update?? What I have to do with it to fix the problem?
silantharakans
How can I affix the problem by using PCC?? Could you please explain it?? What's meant by SUS??
silantharakans
I tried it. But it's not affixing the problem.
florenzgonzales
have you try using other notification sound? ok if it still not working..
download PC companion here:
http://www.sonymobile.com/global-en/tools/pc-companion/
after downloading it open your PC companion. you'll see all the instruction there just make sure you have usb cable to connect it with your xperia P. if you have more question just reply back or pm godbless.
