Notification light not notifying unread message
spian
Notification light is not notifying unread SMS, missed call and other notifications even after the disabling of Stamina Mode. But in my Blackberry mobile a Small notification light notifies properly. What should i do???
Even i downloaded an app called Ilumination Bar but then also it's not working. It works on Album, Walkman, Movies apps.
Amey
1. Turn off stamina mode.
2. Update to latest firmware (12.0.A.2.254)
3. Go to settings -> Backup & Reset -> Factory data reset. (Make sure you backup your data 1st, it will delete your phone data).
That's all I did and it worked for me.
6 REPLIES 6
SatishAryan
Make sure that you switch on the led notifications in settings.
in case if u did and it is not working means i think its time to repair your phone with sony pc companion or update it with sony update service again.
spian
Yes, i have enabled notification from settings. Already having .254 update. Does it notify for unread SMS on your phone???
Amey
It do works perfectly on my SP.
Turn off Stamina mode
Try doing Factory data reset.
spian
Please tell the steps or provide me a link
Amey
OaKy
Hey Spain can you tell me if  after you did what Amey said , your notification bar worked as beafore with 3 leds fading in and out , not with 1 led that lights once at 2-3 second.
And also if it works with stamina on ( all 3 leds ) .
