when i first got the phone is was fine
i had full connection and everything
now
idk what happened
but no connection at all!!
all i have is a red x on the connection bar
and my using the same network carrier and same sim
i thought maybe it's a system problem
so i tried to repair the phone with the pc companion
but i'm stuck at this
i do what it says but nothing!
the phone turn on and that's it
so what should i do now?
Previous reply of mine has gone due to roll back of forum
Did you follow it ?
There might be a problem with your sim card, Try taking out the sim and reinserting it
If that doesn't help then repair your phone . It should rule out the problem
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
http://www.sonymobile.com/global-en/tools/update-service/
Do not repair it at this moment
Go to settings > more > mobile networks > Network mode > select GSM only.
( Or if it's already on GSM only then select WCDMA only
i did this and i got two bars of connection
then a red x on the connection bars
and when i search for providers i get nothing
idk why
i always have providers
i'm trying to make my search manual
but i select it and it sill automatic
Did you follow it ?
thanks so much for your help
it wasn't working at first then i tried on my other laptop
it worked!!
thanks so much
i have full connection now ^^
