LT30p automatically reboots
shom
Hello Sony
Yesterday i installed the 4.3 update from Sony. Today my Phone reboots about 4 times an hour. Saying sim/uim  and sim/uim inserted. .
Factory reset don`t work! (approximately one day work then start rebooting every 5 minutes)
PC Companion repair don`t work! (approximately work one day  then start rebooting every 5 minutes)
Seus don`t work! (approximately one day work then start rebooting every 5 minutes)
Tried it by pulling it out and putting it back several times! (approximately work 2-3-4 hour and then again....)
and sometimes phone lost gsm network, but it happen relatively rare
Is there someone Who can help me?
profile.country.RO.title
_alexdon_
In this case,I suggest you either try a new SIM,just for the record.If that does not help,visit a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
19 REPLIES 19
_alexdon_
alexdon
shom
Thank u Alexdon, I will try change sim but I doubt it because problem start from update 4.3 and i can not find solution in web, meny people have this problem after update 4.3 and they can not slove this problem, i think downgrade will work but i don`t want root phone, I did not expect such problems with sony.
Thanks Alex!
P.S I think there is not sony service center  In my country : )
_alexdon_
You can downgrade without rooting:
http://talk.sonymobile.com/t5/Xperia-S-SL-acro-S/How-to-manually-update-root-downgrade-2012-Xperias/...
But it could be best that you wait for the next update.
alexdon
Thommo
For downgrading I recommend this tutorial which also has a list of firmware's you can download
All you need to do is sign up select the firmware and click on it - On that page will be a download link for the firmware along with full and clear instruction with download links to Flashtools which is need to flash and or downgrade
rcrdofjrdo
I will try this as well. Have the same problem, which is a shame as the update is brilliant. By the way, I tried changing the sim to a new one and made no difference
Motaleb
Sony Xperia T (LT30p) auto restart again &again
0xdb
I have the same issue - unexpected  my phone reboots apr. 3-4 times with the massage "sim/uim card inserted, restarting"
_alexdon_
If you let the SIM out,how is it?
alexdon
0xdb
without sim card it looks ok, but this issue happens relatively rare and totally unpredictable. i can't test it so long
