I think my low battery mode is not working...
I made my wifi and data connections on and activated the low battery mode..still the phone indicates wifi and data connections are are activated..the screens brightness is also not going down as per settings in the low battery mode.
what can i do?
Low battery mode Just in case your battery is less than %30 (Adjustable) of the charge is activated.
Yes..I have selected all to be stoped..and brightness at the min level..
Thanks..how does you adjust the percentage?
Setting > power management > Low battery mode (tab to the left side of it to adjustment)
got it ..thanks
Or just erase everything in the phone itself
