Делитесь своим опытом!
my brother gave me this xperia x2 w/c he bought from UAE... i had it reset to original setting... them boom, theres my problem, i cant understand the language, it arabic and not a 1 word i understand. can anybody help me cange it back to english? it would be a big thankz
Решено! Перейти к решению.
solved......
long press on the homescreen and then choose (plus sign) add shortcut, it would probably appear in english,,, (hope so) then select settings>spb shell> ok....
explore a litle with just 3 choices. and u'll find the language
goood luck
does it work with you? i got sony X2 also from my mom and its in arabic now, i did master reset it then viola! ARABIC.
