How do I know what software my phone is using?
Xperia S. Looking in the "About Phone" in settings only shows Android ver, model, Kernel ver, Build # etc but no software names?
I'm on Android 4.1.2
To add the Xperia S will no longer receive updates and Version 4.1.2 as above been JellyBean will be the last for this model
