How to replace my Ultra T2 old Casing, pad keys
Hi @Yomi, welcome to our forum!
I'm not quite sure that I understand what you are asking about. Do you need to replace certain hardware keys on your device? If that is correct, I would recommend that you get in touch with your Local support team so they can arrange a repair for you.
I'm sorry if I misunderstood your question!
Yes you are correct also my external memory card slot is faulty.
Nigeria doesn't have local support centre.
My 2 Sony xperia phones are having hardware issue & I can't find replacement & repair in Nigeria so frustrating!!
Hi again @Yomi, sorry for the late reply. I have been out of office due to vacation.
You can contact the local support in Nigeria directly on the Email address below and they will be able to provide you a more detailed answer on how to get your Xperia devices repaired.
questions.ng@support.sonymobile.com
I hope that helps!
