Hi
How do I check my Xperia P serial number as its have a non-removeable back. Is there some other way around?
Thanks Mate
I got it.
Anytime
hai my name is jithin......i have xperia model lt18i..........but it shows lt 15i in the software............i check the internal spec with bechmark software.......it shows onle 1024mhz speed.............what is the problem
Type *#06# in your Mobile Phone and find your serial Number.
