how to a hard reset Live in Walkman wt19i ?
Hi.
How to make a full format (hard reset) the smartphone?
If my system is not start, how to a hard reset?  It's keys combination ?
please answer.
Regards.
19 REPLIES 19
does your phone has any charge left? turn off your phone, take the battery out, put it back on, press the power button does it turn on? does the LED flash RED? if it does flash RED then you need to charge the phone.
Try nabeelarza's suggestions but turn off the phone then press and hold the Volume Up and power at the same time, if that doesn't work try Volume Down if not then try both volume keys and power up, this is assuming that you have at least 50% of your battery
My phone is working normally. I want only ask.
If my phone (sytem android) accidentally brick (for example: on holidays), is possible hard reset (repair) without computer and internet.
Best regards.
Nabeel
Master
BRICK ??
now thats a different thing
you could have asked this earlier Neutral_Face
the answer is no, its not possible wothout pc and internet
Thanks.
I only want information, for the future Slightly_smiling_Face
BEST REGARDS !!!
sourav150593
Go to settings -->> Privacy -->> Factory data reset. It will erase all data on your phone and if you wish you may also erase the contents on your SD Card.
how to get ride of a brick . i think my fone got bricked during ICS upgrade Slightly_frowning_Face
repair it with SUS or flashtool
Update Service (SUS)
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
jaybaong
plz help me …my wt19i is restarting again and again
it shows walkman logo only n then it jst restart ….so plz help me out
Bigyo108
Me toooooo Slightly_frowning_Face
