Hello everyone,
I have a problem, Phone is not included no charge LED does not work. What to do?
phone not incl .. On the battery is not being charged LED does not work ....
I don't quite understand, what is not included? included where?
Are you trying to say that when you connect your phone to the wall charger, the phone doesn't charge? are you using Sony's USB cable and wall charger?
