X10pro does not remain connected to WiFi constantly. after some time the WiFi symbol on the top bar goes away. I have to manually open a browser and navigate to a page on internet to re-enable the WiFi connection. It is as if the connection times out.
This causes the RoadSync email client to stop checking for emails and also stops the TuneIn radio application from playing the radio station it was playing.
Anybody got a solution for this issue?
Trying changing the option for Wi-Fi sleep policy.
From the Home screen, drag upwards, Settings>Wireless & networks >Wi-Fi settings>MENU (left hard button)>Advanced>Wi-Fi sleep policy, select 'Never when plugged in' or 'Never' ?
Have fun.
Thanks!! Just set up now testing
This should work
Now that I think of it, There should be a way to swich WiFi on/off as part of a profile that can be switched easily
