display trouble
Tyrael
display trouble
Hi everyone, that is my problem with t3 display https://docs.google.com/file/d/0ByRsrMvprrTEVUw2dGI3X2lMQXc/edit?usp=docslist_api
I can't do anything on my screen because of that top right anomalies. Like someone put his big finger on that place. That problem appear often and suddenly when i typing a message or surf the web. After switch off and switch on that problem disappear, but this is not good for me. How can i fix this? Thx.
Tags (1)
Thommo
Try performing a system repair  - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If that fails then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
4 REPLIES 4
Thommo
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Do you use any screen protector? If yes, do you have the possibility to try without this? Also make sure that there is no dirt on your display that may cause this behaviour. Otherwise, I suggest that you follow
Tyrael
Hi Hampus, Hi Tommo and thanks for advise. I never use screen protectors for my sony phones, that kills all their beauty. Also I love that device and keep it fine. That top right anomalise always used to arise at this position.
Now I finished system repair as Tommo said, and watching for my T3 work. Hope that fix it all.
Thanks again, good luck.
Tyrael
Thx guys it seems my problem were solved successfully. I watched to my phone for a week, and I have concluded that there are no more anomalies. So Thank You! Good Luck!
