Connect Internet using Sony Ericson x10 mini pro
Am using Sony Ericson x10 mini pro. I installed PC companion and PC suite in my laptop. When I connect mobile to laptop I see two option 1.Charge phone 2.Connect USB.  I selected Option 2 to connect my mobile to laptop to use internet from mobile.
Through PCSuite and PC Companion am not able to access internet. In PC Suite it shows mobile not connected. Kindly help me:smileysad:
47 REPLIES 47
I installed PDANet both in my PC and Mobile. But it was unsuccessful to detect. It was asking Port number and Host number. I entered but it was recognizing only mobile devices not my laptop. Bluetooth was also enabled at that time.
Then I installed SE PCSuite.I observed one thing during connecting process. That is When I check the USB debugging option in mobile then for some time it starts to connect mobile to laptop but suddenly it gets disconnected.
I think it will not work out, will buy some data card only:smileyplain:. Thanks lot for your help!!:smileyhappy:
try other apps there are myriad options on the market
like
https://market.android.com/details?id=com.tethernow&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5.....
this works really good, you have to 1) root then install 2) Barnacle
https://market.android.com/details?id=net.szym.barnacle&hl=en
on your computer go to
market.android.com type tether and voila
When I open PDANet application it ask for 'Set Network Proxy' . What host name and Port should I give? I think host name is the my laptop name(which i get in cmd =hostname) but what is the Port here?
For EasyTether am not getting what setting I should set? :smileyplain:.
2 years back i was using W810i that time I was not facing any problem but after buying 15K mobile problems are getting increased. More Money makes human more disturbed and unhappy Smiling_Face_with_open_mouth_&_closed_Eyes
suze
Leader
I have just connected my X10 with PDAnet, in fact this answer is being sent using my data connection from my phone.  I cannot reproduce the problem you are having with your set up so I would suggest you look over at their website for troubleshooting ideas... http://junefabrics.com/android/faq.php
Suze thanks again:smileyhappy:. I find lot of FAQ's in that site, have to find correct one in that:smileysad:.
Once you run PDAnet in X10 dont you get any input field like Enter Hostname and Port?? Anguished_Face
suze
Leader
Nope, I turn it on on phone and then click icon on my tool bar on my netbook (running WinXP) and it says connect to internet which I then click and away we go. Have you tried different usb ports? Is ISB debugging switch on on your phone?  I really don't know what else to suggest, I am so sorry Slightly_frowning_Face
suze
Leader
I'm just giving my X8 a charge and I will re-download the app on there and see what happens.  If I find anything useful I will come back to you.
Oh dont feel so bad:smileyhappy:. ISB debug is also ENABLED.
I will enable all options in my mobile and will try Smiling_Face_with_open_mouth_&_closed_Eyes once. I will not leave this problem as it is will make it to work one day Smiling_Face_with_Sunglasses
Hai one thing I forgot to tell, I have installed PDANet in my friend laptop through the link which you have told. I clicked on Instal button and it got installed but am not able to see it in tool bar or the path where it got installed. I tried to search in Add and Remove programs , Search field in Start .
If i try to install it again it will instal but not finding it where it is hidden:smileywink:. Sorry to post lot of problems ha ha Smiling_Face_with_open_mouth_&_closed_Eyes
suze
Leader
Tried with my X8 and it worked fine too.
Just tried searching on my netbook to see where it saved and its within the normal Programmes file.
The only difference I can think is that I have an older version of PDANet on my Netbook, V2.45 - older versions are still available from their website http://www.junefabrics.com/android/downloadold.php so it might be worth a try.
