Am using Sony Ericson x10 mini pro. I installed PC companion and PC suite in my laptop. When I connect mobile to laptop I see two option 1.Charge phone 2.Connect USB. I selected Option 2 to connect my mobile to laptop to use internet from mobile.
Through PCSuite and PC Companion am not able to access internet. In PC Suite it shows mobile not connected. Kindly help me:smileysad:
thanks to reply... but im getting this image
I connected PDAnet tablet 1.06 , which ask for two options
1. Run as client (tablet)
2. Run as server(phone)
I selected 2nd option , then it switch on bluetooth and connects but not able to use internet, again it ask same message
Above action done in Mobile Phone
that's normal, what do you get on your phone when you start PDANet?
In laptop i dont see any application opening. I just go to start then programs click on PDAnet icon - that messages pop up.
In mobile when i click pdanet icon it ask two options
If i select 1st option then it ask for hostname and port. totally im confuseddddddddddd
Ok its night 2AM here. I will sleep now. Kindly please post the solution if you find it. I will check it tomorrow morning.
Problem from laptop is solved but now im facing from Mobile , very crazy :smileylaugh:...
Ok please do one thing kindly send me the link from where I can download PDANet in my mobile for my mobile. I am using 2.45 version in my laptop. SHould I use same version in mobile:smileywink: too
on your phone go to
settings -> applications -> development -> USB debugging must be selected
USB debug option has been selected. Thanks will try downloading PDANet from the mentioned link. Will see when it will be successful ha ha
