camera & foto problem
akaliptos
11 REPLIES 11
taboo5200
Indeed, image quality is really down the the actual hardware components involved, like the sensor and lens arrays (or lack thereof), though other factors can play a role too (jpeg compression, ewww yuuuuuck!). You could have a camera that captures 30, 40+ MP images that suffer from terrible artifacting - sure, the images churned out are enormous with dimensions that match the manufacturer's claims exactly, but when you consider the resultant quality of the image up close at 1:1 scale, you feel underwhelmed because it looks so bad (lol).
Rule of thumb: There's no way that a company that manufactures both types of products will allow a cheaper all-in-one model to dethrone a higher-priced, dedicated model with regard to performance. That would be strategic suicide.  :v
daniboy9339
I need help my flashlight of camera doesn't work. xperia l
