About WiFi Direct
faisal3dfx
About WiFi Direct
Hi guys,
How are you all? I hope you guys are doing fine. Today I've a question about WiFi Direct. I am using Sony Xperia TX model and I know that it has WiFi Direct function. Now my question is my laptop or my Sony bravia tv don't have wifi direct. So os there any adapter or card out there which I can install on my laptop or my tv to get access to WiFi direct? I want to mirror my whole mobile screen via WiFi direct. Please help me how to do it.
Thank you so much
Faisal Amin
Tags (3)
Look for a WiFi direct dongle for your tv
6 REPLIES 6
If you install a custom ROM, 4.4.4 you might be able to use chromcast
faisal3dfx
@uliwooly thank you man for your reply but can you tell me an specific brand or a name of dongle? I found many on Google but a bit confused about which one should I buy.
Thank you.
Hard to tell as I don't have one myself
faisal3dfx
It's ok bro. I found 2 products on internet. 1. Belking Miracast. 2. Netgear PTV3000 boot products are good but the Belking is a little bit laggy. I am planning to buy Netgear PTV300.
Thank you so much for your valuable replies.
Anytime Slightly_smiling_Face
