That I do not know,check it with Sony:
http://www.sonymobile.com/global-en/support/contact-us/
Read more here:
/t5/Xperia-Z-ZL-ZR/needed-help-with-charger-for-xperia-z/td-p/373667
881 and 880 are both quick chargers.
The difference seems to be the type of cable
http://www.amazon.com/Sony-EP880-Micro-USB-Adapter-Replacement/dp/B00DX5A0MM
http://store.sony.com/micro-usb-quick-charger-zid27-EP881/US/cat-27-catid-All-Phones-Chargers-Cables
