Hello one and all,
I have been plagued with problems with my M5 recently. Firstly I have error messages about my system UI, please see photos below. Last time I had this, I was advised to do a factory reset, and that did not cure the problem, as it has come back again. Note the date of 18th January 1970.
The next problem has been with the camera. Sometimes when the phone is taken out of standby, or picked up for use, the camera switches itself on.
Finally, today, my alarm "snooze" didn't go off this morning, and since then notification sounds became initially truncated / shortened and now I don't have any notification sounds at all. I have run diagnostics, and checked that the notification sounds are set, but no sound. Incoming calls seems to work OK.
Can anyone out there offer any advice.?
Hi @Amazingmin,
I am sorry to hear about the issues you are having with your M5.
Based on the information provided I recommend you run a software repair on your handset. You can find the steps on how to do this here:
Hi @Amazingmin,
