How to use the Sony Portable Wireless Server
jaylward
7,867  Views
The “Portable Wireless Server” (PWS) is a stadalone wireless storage device for your Smartphone and Tablet.
Using the PWS, you can easily store photos, videos, music or office documents to the removable SD memory card or removable USB stick, and wirelessly stream their contents to or from your Smartphones, Tablets and even PC's.  Allowing up to 8 concurrent users access to this device at any one time, collaborative working or broadcast sharing is simple and efficient.
As well as being the ultimate portable wireless server, this handy little device also doubles as a battery backup device for your smartphone!  Plug your USB charger cable into the PWS and the other end into your smartphone, and you can recharge your smartphone on the go - you can also use the wireless server function while chaging your phone!
