Sony Bravia KD-43X8309C and Sony soundbase HT-XT100 connection issues
Peco141
As titled:
Just picked up a new XT100 Sony soundbase to pair up with my Sony Bravia KD-43X8309C but getting constant connection issues.
The audio always works. It sometimes TV speaker and sometimes sound base sometimes both giving a weird delaying sound a millisecond apart.
I have the connection of HDMI straight from soundbase to TV Arc input to allow the TV and Sky remotes to work.
Sometimes I switch on and all works fine. Sometimes a message appears advising "TV speakers active due to audio system communication failure".
When I go to Sync menu on TV remote and choose Control audio system the home theatre control give a list of compatible audio systems but the HT-XT100 is. It listed.
Any help appreciated or should I just return it to retailer?
3 REPLIES 3
Anonymous
Hi there
Quite often the issue your experiencing can be resolved by changing HDMI cables.  Suggest trying another one, even if the HDMI cable is new.
Also have a read through this FAQ:
https://community.sony.co.uk/t5/android-tv/hdmi-problems-troubleshooting-steps/td-p/2141941
Peco141
Peco141
Tried different cables n all sorts. Ended up returning it. Quite disappointing.
