Length of cables for home cinema systems
profile.country.da_DK.title
Keallu
Hi all,
Can anyone tell me the length of the cables (in meters) for the rear speakers are for the systems:
BDV-E190
and
BDV-E690
It isn't stated anywhere in user manual or sales material which is odd to me. I need to know that the cables are long enough before I invest in the system I want. I've read in some forums that they are not very long but not exactly how long.
Thanks in advance,
Keallu
Catmambo
I think they are about 8 meters or so from memory, but don't have one to actually check. However they are easy to change for alternative longer ones if needed as they can be unclipped easily. If you checkout your nearest Sony Centre, John Lewis or bigger PC World, we have very good instore guys & girls who will be able to show you.
Hope this helps
