Hi there
Firstly, can I assume that you have connected the CT660 using only a HDMI cable and not an optical cable as well (just double-checking, thats all)
Try the following
Hope this helps
Hi there
If you are using an older HDMI cable, replace it with a newer one, as that can cure issues.
If that still fails, its probably time to contact Sony Support : HERE
Hey there
I've not seen any list on Bravia Sync. However I am pretty confident to say that all home cinema/theatre equipment that has HDMI from Sony since 2010 will have this feature. Bravia Sync (or HDMI-CEC) has been around for quite a while now.
I have double checked your equipment specs, and Bravia Sync is listed for both
I dont understand why its not working for you. You seem to have the right cable and compatible equipment, you've done all the enabling of it.
However there is a couple of things you may have not done (and im sure support will request you do) is :
Hope that helps
I have just realised that the HDMi cable is only the 1.3 version. I'm now wondering if this will work only with version 1.4?
Hi there
According to Wikipedia : HERE - HDMI 1.3 does NOT support ARC, therefore you must get a 1.4 cable. So that might be the cause of all your problems.
