Bought my brand new CMT-SX7B and set it all up successfully, including setting the FM radio preset stations. But when I try to set the DAB presets, the Menu button doesn't do anything and I can't select 'Tuner Menu'. Or anything. I have tried to update the software but the message comes back "No need".
Hi David,
Did you do the "Initial Scan" first?
Before you can tune in DAB/DAB+ stations, you must perform a DAB Initial Scan.
When you have moved to another area, also perform the DAB Initial Scan manually to update the DAB/DAB+ service information.
Peter
Have you tried unplugging it from the wall and leaving it to depower for a few minutes before trying again?
