Help please
Laine42
Help please
Have purchased more books from Kobo which have downlaoded onto my pc - but every time the reader sync's with the computer the latest books do not appear onto the reader. Have not had this problem before. Can anyone please advise ( there are just over 100 books on the reader)
thomasn75
you need to import books into reader software. go to menu and there will be an option to import/add new books. then you have to find folder where kobo books are and click and import.
because you are not buying books from sony they will not automatically be included in sony software
thomasn75
