Hello paulneagu - Welcome to the Sony Forums
Unfortunately you have posted on the English forums and your message is in Romanian. The Romanian Sony website doesn't currently have an online support community.
I have tried to read your message - are you having trouble getting the zoom lens to function correctly?
If possible, you could try editing your original message above and writing your question in English.
Thanks,
Simon
1. when I close the device is no longer withdraw, lens block 2. the zoom button in-out locks wen i zoom in mechanic . 3. many times appears on display can not play this file can not see video on the screen just pictures. These problems come and go. SORY my sony is dsc-wx7
Message was edited by: paulneagu
Hi paulneagu
It's not clear what the problem with the video playback is, but your main problem with the lens may need specialist repair.
You could try resetting the camera: switch it off, remove the battery, press and hold the shutter button for 30 seconds, replace the battery and switch on. If the problem persists, you should seek out a repair service in your country.
Mick
