Cable from HDR-FX7 memory card to pc
maglove83
Can I ask if anyone knows the cable needed (I am aware that on the pc end its a straightforward usb connector but to the cameras memory card where it holds still images its something else)
Thanks in advance
Sean_Mc
Moderator
Hi maglove83,
This looks like an old product.
It may be best to check on Amazon for the cable you require.
Thanks,
Sean Mc
