Sony C5 Ultra Sensors problem
Mitchael
Hi friends, I need your help.
Update my sony xperia C5 ultra mobile and it turns out that I do not work the operating system, also does not work the mobile touch
And when I start the download the device is turned off
That I have to do?
YoGem
Leader
@Mitchael I am having some issues understanding your post... bear with me, please:
So you updated the OS and after that you had several issues, like touch screen not working...
I know that the Marshmallow update of the C5 was a bit messy, I can recommend you to try using the software repair using Xperia Companion - that will probably fix all the issues with your C5.
