Hi All,
My Sony C5 Ultra has a problem with screen auto rotation, flash light, proximity sensor, light sensor. When I restart the phone everything works normally, but when I get a call, screen goes black(proximity works onces) and then after that call, all other sensors doesnt work. No flashlight, no autorotation etc. I would be very glad if someone can help me.
If your country isn't available in the drop down list on our Local support website you can reach them by sending an email to questions.az@support.sonymobile.com.
Hi @Sah_Mardan, I'm very sorry to hear this.
First of all I'd recommend that you test your phone in safe mode to verify if this behaviour remains or if it could be caused by a downloaded third party app.
If it's the same in safe mode I'd then recommend you to perform a software repair using Xperia Companion. This will reinstall your device's software so don't forget to backup any important data before proceeding with this.
Please let me know how it turned out.
It is same in safe mode. And same problem after repair.
Then I'm afraid that your device is in need of service. If you contact your Local support team they can help you proceed with this if need be. I'm sorry for any inconvenience this causes.
Dear Christofer,
Would you please let me know, who is the official local support team in Azerbaijan, Baku?
Christofer, thanks for information.
You're welcome!
