Which wall mount for A90K 42”
feedMyPixel
Hi I’ve ordered a SU-WL450 Wall-Mount Bracket SUWL450
But I’ve just thought this is only from the suggestion on the Sony Store. Will this wall mount work with the pre-ordered A90K | BRAVIA XR | MASTER Series | OLED | 4K Ultra HD | High Dynamic Range (HDR) | Smart TV (Google TV)
XR42A90KU
And if not which flat wall bracket do I need to get?
Tags (1)
LightFoot
Specialist
3 REPLIES 3
LightFoot
Specialist
Hi @feedMyPixel
That is the one shown on the TV support page including instructions.
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/xr-42a90k
feedMyPixel
That’s wonderful. Thanks for the support page link that will be super helpful
patansl
I just installed mine on a Sanus VMF720 - fully positional wall mount. Works superbly. Can swing the TV almost to a full 90 degrees and is a very stylish arm to look at too.
