KDL 65XH9505 - Led stays on immediately after tv is started
profile.country.RO.title
iLL.ro
Hello
I just noticed this, immediately after i start my tv the small led in the right side of the sony logo lights up.
TV is powered on (plugged to th epower socket), android logo is displayed, then tv starts and displays the home screen.
I'd say after 1 second the led lights up.
I have Ok google turned off... and have not used it. TV has the latest version installed, every software is up to date.
Tags (2)
2 REPLIES 2
This is a known issue that is under investigation currently.
Please use the following workaround:
Press the mic button on the remote button followed by pressing the TV button twice.
Peter
iLL.ro
Thanks Peter :slight_smile:
I also noticed that if i use the remote to do a "google search", then exit the menu after display keyboard appears.. the led stops.
