KDL-43W807c connection to sound plinth
gandee45
Hi, I recently bought the subject TV, and have connected it via an optical lead to a Denon KT-100
sound plinth.
When the TV is switched off the plinth continues to "pop" and may do so randomely for hours.
Whilst this is not a die in a ditch problem, it is agravating, and perhapes someone can offer advise on a resolution.
2 REPLIES 2
Anonymous
Hi there
It sounds like an issue with the soundbase itself.  However, try setting the 'digital audio out' to 'Auto' or 'PCM' in the TVs sound settings.  if that fails, try another optical cable.
gandee45
Thanks for the suggestions. I will give them a try and report back!
