Is it possible to disable Youview on an OLED AG9 TV without retuning?
djwadley
Have recently purchased an AG9 and have installed Youview. Apparently I cannot record from Youview to an external drive. Is there any way I can disable Youview without having to go through the setup process again?
2 ACCEPTED SOLUTIONS
Sean_Mc
Moderator
Hi there,
It should be possible to disable YouView. You can see more details how to do this here.
Best wishes,
Sean
djwadley
Many thanks for the reply.
Yes, that works. Problem solved.
3 REPLIES 3
Sean_Mc
Moderator
Hi there,
Best wishes,
Sean
djwadley
Sean_Mc
Moderator
That's great to hear. Thanks for letting us know!
Best wishes,
Sean
