Bluetooth problem on KD-65X8509C
profile.country.SE.title
mrcodec
My tv set has been acting weird lately. Everytime I turn the TV off (on standby) the Bluetooth gets deactivated. I need to engage the settings menu everytime. Super annoyed by this because the Bluetooth remote doesn't work.
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
Can you tell me if your remote stopped working after updating the TV's firmware?
Best wishes,
Sean Mc
mrcodec
Hard to tell. I have not experienced this problem for too long. The latest firmware update feels like a longer time ago than the problem with the remote and the bluetooth setting changing without no reason.
batee5
Specialist
Hi mrcodec,
Welcome to our community!
It seems like the TV forgets the Bluetooth settings when put in standby mode. Could you try to reset your TV to factory settings and see if this resolves the issue? You can do that by pressing Home the navigate to Settings > Storage & reset > Factory data reset.
Let us know if this makes a difference.
Regards,
Batee5
mrcodec
Let me test this and evaluate. I will bring you an answer within a week!
