Transfer raw images to ipad pro 2018
bavarian1
Is there a workaround for transfering images from my SD card on my Sony A7 mk3 to my new ipad pro 2018
the raw image wont load no problems with jpg though.
Tags (1)
2 REPLIES 2
IamNic
Hello @bavarian1,
which software do you use to open the RAW-files on your iPad?
Did you try Affinity Photo? With it I had good compatibility with all Sony RAW-formats no matter the camera on desktop - not sure if it will be the same for the iPad version.
- Nic
bavarian1
Thanks Nic I will give it a try
