Anybody know if Sony provide "technical LUTs" for converting their Log 2/3 video footage in Premier pro. And if so where to download it. Thanks in advance. Dave
Hi Dave,
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Hi @Dave0151
I believe Sony don't because of the wide variety of different shooting situations
and available picture profiles.
Ideally an LUT should be custom made for the video.
Third party generic LUTs are available though.
Hi Dave0151,
I believe there are LUTs available for use with professional products. What's the model number of the camera you're using?
Cheers,
The_Black_Rose
Hi @Dave0151,
maybe those files are what you're looking for? The link is leading to a German site but I'm sure you'll realise which button you'll need to hit for downloading the files
darkframe
