Sony A1 Vertical Display Orientation
Snerkler
I see that the A7RV and A7IV have had updates that enable the display to change between landscape and portrait depending on which orientation you have the camera, is there a way I can contact Sony to ask for this feature on the A1?
I know the A9III and A1 II have it but just assumed it was something to do with the newer processor, however now that the A7IV has it it makes me think that it should be possible with the A1?
0 REPLIES 0
