Is there a way to change the pictures that are displayed when the help guide is shown on the a580?
Hello nithorn58 - Welcome to the Sony Forums
If you are referring to any built in help guide within the camera, the layout will be a manufacturer's default and as such you will not be able to adjust the guide at all - it is read only.
Thanks,
Simon
Thanks Simon
Thought that might be the case - hoped it wasn't.
Cheers, Captain.
