Hi, recently picked up a A7C and I love it. One thing that bothers me though, is that the photo capture time and video capture time is 1 hour apart for some reason. I've turned off daylight savings time, and there's pretty much no other setting to check afaik. Photos have the correct timestamp, however videos have a capture time of 1 hour earlier than actual capture time. This makes it hard to organize photos and videos in relation. Is there a fix for this or some setting I can check?
Thanks!
Hi magnews,
Most likely this is software glitch. Try to set the date & time to Area Setting by pressing Setup - Area Setup - Then select the desired area.
If that didn't help, try to initialize the camera settings by pressing Setup - Setting Reset - Initialize after removing the batteries for a few mins.
